- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss
Is this consistent with what you would charge on a bought item?
Would it be different if you had to research and find the product yourself and have the customer approve?
Not trying to get nosy - general fact finding. :) Thx in advance.
Cheers from: Jeremy Pollard, CET The Caring Canuckian!
www[.]tsuonline.com
Control Design www[.]controldesign.com
Manufacturing Automation www[.]automationmag.com
In the end, though the customer is going to go around and get their three or four quotes for the complete project and base their decision off the bottom line.
Some shops use the markup method, while others simply say 0% markup but then explicitly estimate a certain number of manhours plus cost of working capital. Some places use a mixture of the two methods, depending upon the cost of the individual item. Since they are normally giving the customer a fixed quote for the project anyway, how they estimate it out is an internal matter.
Having seen it done both ways, I would say the markup method causes more difficulty. The problem is that it treats everything as more or less the same, which is only true for small, simple jobs. The people doing 0% markup seem to run into fewer difficulties because they aren't trying to apply a single rule to all cases.
The biggest failing of the markup method of estimating is that you can on one hand have an expensive but routine item that is easy to deal with, and on the other hand have an inexpensive item that requires a lot of research. You will overestimate your costs in the first case, and under estimate them in the second. You'll then try to fudge the numbers up and down because you know they just aren't right. So why not just estimate what you really want to know in the first place?
In the end, the margin you accept depends on the 'bargain' struck between you and the buyer.
There are certainly cases where we take less than 30% margin, but 30% is our target.
Iris Felzenhaus
- PLC origins: Where did PLCs come from? 40th anniversary timeline
- Green engineering: Automated system makes engine repair eco-friendly
- Acoustic measurements: Tutorial on decibels, microphones
- Vision help: Service helps users implement imaging algorithms
- Data integration: See, use, study integrated automation information
- OPC: Easier software; IEC 61131-3 programming for unified architecture, training
- Radioland: Wireless spread spectrum, frequency hopping, data radio devices
- New EZ Jump terminal blocks from ASI
- Hammond Control Power Transformers, more industrial options
