Dear Fellows,
I want to use the simulator of Experion PKS R300. I'm facing the problem in its installation.
When I insert the application DVD, I can install either the server application or the simulator application. Installing the server application doesn't let me install the simulator afterwards, while installing the simulator application doesn't let me install the server application. Let me explain it a bit further:
When we insert application DVD, a dialog opens and it says to select either Server, simulator, and etc. Only one selection can be made at a time when I install server through this. The process went fine, and I get no problems. But when I again insert the application DVD to install the simulator, it detects the current version of Experion and aborts the installation. Similar thing happens when I first install the simulator, and then when trying to install the server software, it detects the Experion installation in the system and aborts it.
Can anyone help me how I can install the simulator and server simultaneously? I basically want to work on simulator.
I shall be very thankful to you for this help.
