We recently changed a centrifugal pump which is operating with VFD.Motor and VFD is rated at 132 KW (maximum 240 Amps). The new pump came with 180 KW motor. But the pump capacity and HP is same as before 120 KW. Will the VFD function with the new higher rated motor without overloading? what can happen during startup? what will be starting current? your valuable reply is awaited
