from the Forum department...
Thermowells lenght inside the pipe
Posted by ibrahim abdel mohsen on 26 March, 2009 - 5:59 am
can any one advice me what the recommended lenght of thermowell inside the pipe? and what is the relation between the lenght and velocity of the flow and the accuracy of measurement (the application is on gas plant)
Posted by Anonymous on 27 March, 2009 - 1:15 am
Dear
You may purchase or get "ASME PTC 19.3" document for details or You may simply "Google" this document on internet.
Hope Your Problem will be Solve.
Posted by Roy Matson on 27 March, 2009 - 11:27 am
It used to be common practice to have the thermowell protrude half way across the pipe. I think that's OK up to about 6" but I don't see the point in going in more than 3".
It also depends on whats in the well, thermocouples are tip sensitive so only the end of the thermowell needs to be at process temperature wheras something like a bi-metal thermometer or filled system bulb has a much longer measuring element so it needs to be in further, about 2" for a Bi-metal.
Roy
This is your fortune.
Advertise here
advertisements
MatrikonOPC has over 500 OPC interfaces and out of the box software. Find an OPC Server for your devices here.
our advertisers
