from the Forum department...
use usb arcnet with TCI and cimplicity
Local and wide area networking in factory automation. topic
Posted by Luca C. on 16 April, 2009 - 8:15 pm
Does anyone know if is possible use a usb-arcnet coax (contemporary control usb22) to connect a notebook with TCI to a mark V?
Posted by marco on 25 April, 2009 - 7:08 am
Hi Luca C.,
i will try (in one of the upcoming weeks) to connect to mark-V(LM) via a usb-Arcnet-device in order to set up an opc-connection with Matrikon's OPC-Server. If it helps you, I can give you some information afterwards. But i guess it should work...
Best regards,
Marco
Posted by Luca C. on 27 April, 2009 - 6:16 am
Hi Marco,
all information you can give me are
appreciated.
Best Regards,
Luca C.
Posted by agi on 25 September, 2009 - 10:44 am
Sir,
May I have the information too ??
( to connect to mark-V(LM) via a
usb-Arcnet-device on NB )
My email is agichen@gmail.com
Agi
Posted by marco on 26 September, 2009 - 8:07 am
Hello Everybody,
I'm very sorry for my late reply. What I can tell you guys so far is, that I've successfully set up an opc-connection to MKV-LM with a WinXP-Notebook. I am currently using the opc-data-logger and opc-data-viewer from LH-controls to log engine data and being able to examine some issues with turbine's DLE/Tflame control. I've never had such a deep insight to the engine's process before, as the connection runs with scan time of 0.1 - 0.2 s and the handling (signal selection etc.) is very easy. The next thing we try to do is to clone one of our HMIs by using acronis-harddrive-image-software and connect a spare win-NT-PC (which has no stagelink-PCI-card) with the arcnet-usb-driver. If this works, then it should work with a NB as well. But the better solution from my point of view would be to get it running with a virtual Win-NT system on a WinXP-Notebook, as this would make us independant from obsolete PC-hardware. But I guess the usb support of virtual systems still is problem...
As soon as I have news to tell I'll give you the information!
By the way, does one of you guys have experience with LM2500+DLE engines?
Best Regards,
marco
Bore, n.:
A person who talks when you wish him to listen.
-- Ambrose Bierce, "The Devil's Dictionary"
Advertise here
Advertisement
our advertisers
