from the Forum department...
Read Weight from Mettler Toledo Scale via RS232
Sensor technologies. topic
Posted by Martin on 20 April, 2009 - 2:56 am
Hi All,
How can i read a weight from a Mettler Toledo Scale via RS232
I have written the coding to read the data from serial port.
I am very new ..working to read the weight(mg) data from a mettler Toledo via RS232 using VB.Net
please help and pass me any coding or idea.
My mail id: asasamy@yahoo.com
Thanks in Advance
Posted by Tom Chubb on 20 April, 2009 - 9:02 am
Try this: http://lmgtfy.com/?q=mettler+toledo+text+string
The following link shows the structure of the ASCII string on page 13
onwards.
www.usedscales.com/8213.pdf
HTH
Tom Chubb
JCK Automation
tom@jck-automation.com
www.jck-automation.com
Posted by Earthed Solutions on 20 April, 2009 - 10:39 pm
I understand that you want to capture Mettler Toledo RS232 port weight data in a VB.NET application. And you are after source code for VB.NET.
To query the scale, you need to send an ASCII command:
S<CR><LF>
To process the returned weight:
<?><LF>S S 0.000 lb
<?><LF>S S 0.000 g
It would be best to extract the value and the units and then implemenmt a switch statement on the units toi convert to a standard weight.
I would suggest reading the captured string into a string seperator using space " " as the delimiter such that
str[0] = "<?><LF>S"
str[1] = "S"
str[2] = "0.000"
str[3] = "lb|g|kg|..."
then process the result
Which version of VB are you using? - I might be able to supply VB.NET 2008 code.
www.earthed.net.au admin@earthed.net.au
Posted by Fred Loveless on 21 April, 2009 - 9:43 am
Ultimately what is your goal, i.e. what are you going to do with the data?
If you are using it in an automated process of some kind you might want to consider useing and OPC Server like Kepware's UCON Protocol Server. UCON stands for User Configurable. You can can create the request and response handling and then connect to the server via any SCADA Client or via VB.Net if you wish. the process is similar to the VB.Net code example that was presented.
Just another option to consider.
Fred Loveless
Senior Application Engineer
Kepware Technologies
http://www.kepware.com
Posted by Lee Munyaradzi on 29 June, 2009 - 2:03 am
> I understand that you want to capture Mettler Toledo RS232 port weight data in a VB.NET application. And you are after source code for VB.NET. <
I'm facing a similar problem. Could you please supply the vb .net code on how to read data from a scale via an RS232.
Don't hate yourself in the morning -- sleep till noon.
Advertise here
Advertisement
our advertisers
