I have an Ethernet Module connected to a PLC. It is communicating well with PLC and is working fine. I wish to remotely Monitor (Digital & Analog points) and Control (operate output coils) on the PLC over the internet. I do not know Visual Basic or C++ programming languages. I wish to create process graphics on my PC and allocate commands to the monitoring and control point on my PC screen. Could some one please suggest how do I go about it.
use VNC software and install in both computer to make client /server and make monitoring system you can take the program from www.4shared.com
Check out FactoryPMI from Inductive Automation. It will meet your said requirements. You can download a free resettable 2 hour evaluation. They will also show you how it works if you sign up for a "web demo".
Nathan Boeger
http://notanotherindustrialblog.blogspot.com
Nathan Boeger
If you only have a hammer, you tend to see every problem as a nail.
-- Maslow
