Hi guyz!
In a Power Monitoring Project I'm facing a situation in which data from the Relays is coming in the form of Modbus via TCP over Ethernet. But I want to convert it into Modbus TCP.
Can you suggest me any software or device that will do it? I know some devices that convert Modbus RTU into Modbus TCP but they work as serial to ethernet converters. I just need to convert the application layer, that is, from Modbus via TCP to Modbus TCP.
