I have an application using Control Logix and a purchased device using Modbus Ethernet TCP/IP. so far I cannot find any supplier that can support the Modbus Function Code 43 which I need to use to tranfer data between Control Logix PLC and the device needing the data. So far Molex, Anybus, Red Lion, Prosoft & Kepserver do not support this code. Has anyone run ito this and solve the communications?
