Have a mixed natural gas liquids stream that has a smallish fraction (5%) of ethane with the balance being heavier hydrocarbons.
Pressure 300 psig
Temperature 170F
Flow rate about 250GPM
Having trouble measuring this stream, a turbine meter was tried, and removed(unknown why it was removed, before my time) have had some success with an annubar measurement, but due to foreign objects in stream, have damaged two elements. Probably why the turbine meter didn't last either. Annubar was repeatable, but I do not think, absolutely accurate. Going to try a coriolis meter, but I fear that won't work because the ethane is boiling and will cause entrained vapors.
anybody have any suggestions?
I want as accurate as possible.
Pressure 300 psig
Temperature 170F
