X
Fuel line purge timer (L62P). Actually what it does? how it’s purging the liquid fuel line after change over from liquid fuel to gas fuel.
We are having naphtha, gas and diesel as intermediate fluid. I mean diesel fuel pumps are always running and recalculating the diesel in parallel with either naphtha or gas. Naphtha or gas changes over to diesel when it get appropriate problem. This fuel change over is accomplished by a three way valve with 2 limit switches(33TDD&TNC).
This L62P is originating from MANUAL_ST_POINT_LONG block. WHERE this logic is generated from a equal block where KFQLV1X[800 dm3](total naphtha fuel to purge) with FQLV1X. Whenever we are starting and running the unit with gas fuel, the message field shows "fuel line purge is in progress" where I found KFQLV1X not equal to FQLV1X so L62P is logic ZERO. KFQLV1X reads less than 200, and the same time I found in the other 2 units it was matching so the L62P is logic ONE no more "fuel line purge is in progress". In this particular engine we are forcing the L62P and running.
What I think is MANUAL_ST_POINT_LONG is generating some spurious output though control constants are matching with other machines. Plz explain this purging process and my system problem too.
