I have a project that needs to convert a 0-60K Ohm resistance to an analog PLC input. I have found several signal conditioners for this, but the max resistance was always the standard 10K or 20K maximum resistance. Does anyone know of one that goes higher? I was thinking of putting another resistor in parallel, but then the curve will no longer be linear. I can't put any real voltage on the line (>24Vdc) because of the hazard to personnel.
Anyone have any other ideas?
