In an Analog I/P module- for no of Inputs- 16 single ended, 8 differential or 4 High-speed differential means....I need the clear and exact explanation for the clarification mentioned here.
16 single ended - all transmitters are loop powered (one common power supply, 2 wires to the transmitter), low common mode rejection (lower volage isolation between channels, lower noise rejection).
8 differential - multiple transmitters are instrument powered (multiple power supplies, 4 wires to the transmitter) higher common mode rejection (higher voltage isolation between channels, better noise rejection).
