Hi all,
I have a solar package in the field. In it there is a serial to ethernet converter (terminal server). The serial port on this terminal server is used to gather data from a totalflow using totalflow protocol as a terminal server modem.
The Morningstar controller in the solar package has a device called a Meterbus adapter that can be polled via MODBUS ascii/rtu or MODBUS TCP. I am trying to find a device with 2 serial ports that can speak both modbus tcp and be a terminal server. Other option is to add a modbus ascii to ethernet adapter, and a small ethernet switch. I am limited to how much more power I can draw. I have approx 3 watts to play with.
