I'm a electrical/controls technician that has been given the responsibilities of spec'ing drives, motors, breakers, fuses, marking up existing standard elec drawings, putting together a BOM, panel layout, changing standard configuration etc...
I started to put together a "checklist" in MS Word I can use to follow through on each piece of machinery I start engineering. I thought I would ask in here if there is something in the way of a doc. or excel file or some other means that already exists that I can have a copy to use?
If anyone has a PDF file or other information pertaining to the engineering process, what I described above, I would appreciate that as well.
Jeff
Jeff
