G
I would like to better understand the criteria for sizing the turbo machinery lube oil system, with separate lube oil console (i.e. no shaft driven main lube oil pump).
It is my understanding, that the units equipped with API 614 lube oil console can support a failure in one of the two AC lube oil pumps, as the system is sized for allowing the time of re-acceleration and pressure build-up of the stand-by pump, through an accumulator or a rundown tank. Vice versa, the large units, e.g. the F gas turbines, do not have API 614 lube oil consoles, because large enough accumulators can not reasonably be installed so that the sudden failure of one lube oil pump brings to unit's trip. Therefore the standby pump is used to share the operation, but must be started before the stop of the operating pump. In these units is commonly installed a DC emergency pump for safe coast down only.
I would appreciate your advising me whether this interpretation is correct.
Thanks and best regards
