I have a digital weighing scale I need to connect to the vs.net 2008 Application. Every time I weigh an object, automatically the result/weight will display in the the texbox control in Vs.net Application that I made. I don't have idea regarding this. I need your help for the complete source code that will communicate to the weighing device and what control should I use to communicate and how?
please forward u r suggestion to this id:
rajapalanisamy.mca [at] gmail.com
Thanks,
Thanks,
What kind of scale? Comm via Serial, Ethernet???
Hi Fluoronator, i haven't receive response from you.
If life is a stage, I want some better lighting.
