P
We have two GTs and one ST. It was cold-start up and at the time when the plant was tripped due to high high trip for the water level in IP drum, one GT produced 8 MW after synchro. The evaporator in IP drum is naturally circulated. There is a valve located on a pipe which delivers superheater from IP drum to ST turbine and the valve is programmed to be opened step by step when IP drum reaches 10 bar. When IP drum really reached 10 bar, the valve was opened, about 4%. Then, all of sudden, the pressure in IP drum abruptly dropped to 5 bar and the water was swelled to high--high level and the plant was tripped. Is there anyone who can help me understand what could cause this supposed that all equipment in the plant is operated well?
