H
Can some body guide me about the lowest lube oil tank level of 9E machine? I have seen the MLI 416 for this case but i found such thing 254,305,406 & 432 . Is 432 is the low level? I also see the device summery which gives 71Ql and 71QH for low and high level , but doesn't give the valve of the switch . Please guide me for the low level of lube oil tank
thanks
Hassan
thanks
Hassan
