G
I have had a machine panel burn up twice without blowing a fuse at the disconect or a fuse in the machine panel. Voltage is 208 3-phase and measures corectly phase to phase and phase to ground. What can cause this to happen?
K | Turbine compartment monitoring for 9FA machine | General Communications Chat | 9 | |
Machine tripped | Power Generation | 5 | ||
A | Boiler Burner Control Damper Servo Motor Potentiometer Burned Up | Motion Control | 8 | |
M | GE Frame 6B Crossfire Tube Burned | Power Generation | 4 | |
C | Burned Thyristors of AVR - Synchronous Motor | Power Generation | 1 |
