P
If in a transformer the overloading capacity is not mentioned, is there any thumb rule to determine the overloading capacity? example, a 100MVA transformer can be overloaded up to 105MVA considering 5% overloading as safe.
1) If it is mentioned by the transformer manufacturer that the transformer has overloading capacity of 10%. Does it mean that the current can be increase more by 10% above nominal current?
