Hi All,
I'm a first time poster, long time lurker.
I have set up a dos VM on my laptop, I have copied a c:\ off one of our Frame 6 <I> machines and attempted to get it running on my laptop so I can test some changes before actually doing them on the actual <I>.
The problem I'm having is: once the autoexec.bat executes and the menu.exe loads I lose use of the keyboard, which then means I can't exit out to dos or use the rung display etc.
Does anyone know of a way around this? I imagine that I need to comment out a line somewhere so that the VM doesn't try to look for a different keyboard once it kicks off the RUN_IDP
Kind Regards,
Adam
Kind Regards,
Adam
