Guys,
I have lingering questions running through my head. I hope somebody can answers my burning questions.
1. A generator parallel with the utility grid, if let's I want the generator to supply 70% of the total load, the rest 30% from the grid, how to achieve this? generator supplies 50% of its capacity contributes to 70% of the total load. My assumption this can be done through governor control. I believe there is an explanation behind this.
2. A generator parallel with the utility grid, sudden load change has occurred (From high load to low load). my understanding is the generator will export the power to the grid in short period of time, governor and alternator would adjust the speed and voltage according to the reference value. The power supply by the generator would be reduced and generator continues to synchronize with grid to supply the power to the load. no power export to the grid by generator at this point. - Please correct me if I'm wrong.
3. Situation is almost the same as question no 1. a generator supplies 100% of its power to the load. no power export from the grid. the grid is in hot standby mode. Can it be done? if yes, please explain.
