Hi guys,
Suppose I were to increase field excitation (keeping input torque constant) of an isolated synchronous generator feeding a purely resistive load (unity pf). As per alternator theory, increasing excitation will increase terminal voltage of alternator, but the load current will remain constant since input torque is held constant (no VAR output as load is resistive). But how is this possible? Increase in terminal voltage should also cause the load current to increase resulting in increased power output, but the working principle indicates otherwise.
Please guide.
Please guide.
