I would like to know what could happen to the starting current of a Squirrel cage Induction Motor (11 kV, 4MW, 350% Full Load Amps as Starting current) if I rotate the rotor by means of another motor or Turbine up to half of the rated speed or more and then close the breaker of motor. Will the motor take high current it usually would? Could there be any significant decrease in the starting current? Please clear the funda behind high starting current.
Thanks in advance..!!
