How does everybody like to indicate on HMI the state of digital/boolean IO? Conventions on color, shape, text, or a combination that is intuitive at a glance?
Basically I'm just trying to come up with a standard for our own uses, to make our HMIs just a little more high-performance.
Colors such as red/green can be good, but need to be combined with other elements such as text or shape for the colorblind. Text would be good, but some operators are illiterate or foreign and may not understand TRUE/FALSE. ON/OFF could work, or 1/0
I'll also want to visually distinguish between inputs and outputs, each with their true/false states, somehow.
Would anyone with experience out there like to share what they like to use? Or are there some examples of bad HMI practices that really grind your gears??
