Dear All
We have 3 Power GT PGT10 driving a JEUMONT Generators. Usually 2 generators are running in parallel mode and the 3rd one is on Standby. We lost the PMG (Permanent magnet generator) on one of those GENs and the root cause of the damage was due to the PMG Bearings failure.
A new OEM genuine PMG has been installed but we still have the same trouble. The Gen Main Breaker opens due to excitation failure.
During the PMG replacement we also removed the exciter end cover and we cleaned all the armature/Stator area from dirt and dust than we checked and tested diodes, connections, cables and found fine.
My questions are:
How to solve this problem? And what's going wrong with this Generator and its exciter?
When the PMG has stuck and has burned, what's its effect on the other components of the generator?
Thanks In advance
Karim
My questions are:
Thanks In advance
Karim
