Our gas turbine is a GE MS5002D model, designed to run three centrifugal compressors BCL in series (gas compression process).
My question is: if the discharge pressure of the load increase what will happen to the engine (the speed of LP shaft). I mean the turbine request more energy or less.
for example my machine was running at 99%TNL, and the discharge pressure of the header was 220 barg.
if the pressure in the header will be 250, what will happen to the speed TNL?
thank you in advance
