G
I need clarification regarding Can an isolated generator use droop governor?
Is it both isochronous governor and droop governor are simultaneously installed with a generator.
because my question is when in parallel mode a generator was sharing load with other based on droop control. after sudden islanding then governor control should switch over to isochronous control from droop to maintain its own frequency?
or droop governor is capable of giving stable operation in isolated case too?
