Hi Friends,
We have SOLAR Taurus 60 Gas turbine generator in our plant. We are facing problem with turbine start up. During start up sequence after cranking when ignition happened 'Flame out on Low Engine Temperature T5 alarm comes and machine tripped. We have carried out following checks:
1) Gas path thoroughly checked for any blockage. Found cleaned.
2) Primary fuel gas valve, secondary fuel gas valve and FGMV functionality checked and found normal.
3) Air intake filters replaced with new one and IGV opening confirmed to its minimum position.
4) All T5 temperatures found normal.
5) Spark plug checked and found normal.
6) Bleed valve also in correct position.
After all these still machine is tripping in 'Flame out in low temp T5'.
Can anyone help to resolve this issue?
Mitra
Mitra
