I have a technical question.
I have a chiller that contains 3 controllers inside its control
panel. Those controllers are daisy chain connected through Modbus/RTU (RS485) loop end with PLC (as a Modbus master controller).
It is required to control /monitor the chiller signals via BMS.
So, if I consider the DDC (BMS Panel) as Master controller, and the chiller controllers are slaves, shall I override (remove the network wires from) Modbus chiller PLC master controller, and consider the other three controllers as slaves?
please support me.
Thanks and regards,
Mohammad.
please support me.
Thanks and regards,
Mohammad.
