Hi Dear,
We have 4 Gas turbine frame 9e.03 can any body tell me while we are using bearing lift oil pump. Pump discharge is 240Bar to Generator Bearing how much shaft is lift through this pressure. means to say who much clearance is around bearing and shaft to give an oil seal between bearing and shaft.
Another question is why only in big frames this jacking oil system is provided by manufacturer not on small Gas turbine. Any idea kindly share.
