P
We have build an OPC server using an Advosol SDK. The client is Cimplcity.
A script needs to be run on Cimplicity when a specific value is updated, even with an identical value. For performance we want to config the point as unsolicited, but the script doesn not fire when the point is updated with the same value.
I have the following question. Does an OPC point that is set to unsolicited get updated when the server sets it with the same value?
We need it to trigger a script even when the value does not change.
