This topic is not new, but I felt some here might have good insight. I have a plasma cutting CNC table that I built using a cheap control board (MKS DLC32 V2.1). I noticed that when I fire the plasma torch it disconnects the control board from the computer which is linked via a sheilded USB. I've had some luck preventing the interference by wrapping the torch lead and motor driver wires in tinfoil, and running a ground wire from the z-axis mechanism to the control board's power supply case, but I can only acheive about 60 seconds of run time before the usb connection fails. I was advised to try a USB isolator which I will order soon. The computer is connected to a different circuit than the 220 volt plasma cutter outlet but there could still be some interference happening inside the main panel I would assume. I did have a bit better luck running a laptop off battery power but would still error out after about a minute of plasma run time. The best performance so far has been running the g-code file directly off the SD card on the board via a wireless app. As long as the device (phone) doesn't get too near to the work table it will execute the cut without error. But I would still like to run the g-code from a computer since it has more functionality than the phone app/wireless connection.
It is my understanding that plasma cutters (like the cheaper inverter type I'm testing) operate in the 10 kHz to about 200 kHz range. I understand there are several types of USB isolators (galvanic, optical) and was wondering if anyone could shed some light on this situation? I have yet to test star grounding techniques and just want to try one idea at a time to see what method offers the greatest improvements. If the USB isolator doesn't solve the situation I will then go on to grounding the cutting table to an outdoor earth rod. If that doesn't solve the matter I will make a sheath for the torch lead using faraday fabric and ground it to the plasma cutter's case. I will be upgrading the motor wires to twisted pair shielded soon as well. I will also be moving the computer and control board enclosure further from the work area, but for now I want it close and failing so I can test the other options.
Thanks for any advice and tips.
Sincerely,
Robert Hosking
Sincerely,
Robert Hosking
