Hi All,
I am facing an issue with Proficy Historian 2022 when adding tags from collector with error -32 (Operation not Permitted).
I checked everything but same issue, I create a simulation collector to add tag but same issue.
I tried to add tags from Web Configuration Hub and got (Insufficient permissions to perform the operation) and in the logfiles same error -32.
I use Admin session who has all privileges (ih.admin, ih.collector....)
I found nothing about this Error -32 just "Operation not Permitted"
Is there any other parameter i messed?
I tried Historian 7.2 and it works perfect but not 2022.
Please any suggestions to help me because I am stucked.
Thank you
Dino
Thank you
Dino
