The contributors to the thread "Variation in Level" certainly know their 'Pees', 'Iees', and "Dees", while in my case its way over (excuse the pun) my head!
Now, if you can, solve the following problem:
A process fluid tank can be filled by two fill lines in 4 and 5 hours, respectively. It can be emptied by two drain lines in 3 and 6 hours, respectively. If the tank is half-filled and all lines are opened simultaneously, will the tank fill up? Or will it empty? In how many hours?
Phil Corso, PE {Boca Raton, FL, USA}
[[email protected]] ([email protected])
