P
I have been given a project that involves using this bridge to communicate with a PLC via a repeater and polling remote radio. The project involves SCADA control of a multi-well system. The polling engine will make its requests for data via TCP/IP connection to the 174CEV30010 ethernet port. The modbus port will be connected to a polling remote radio (MDS 9790) via a RS-232 connection. The polling remote communicates with a repeater radio (same type) that communicates with the radio at the well (MDS 9710) that in turn communicates with the PLC (TSX Momentum).
Communications and configuration of the 174CEV30010 via the ethernet port has worked fine. The modbus communications via the radios to the PLC has not.
Is this a good application for the 174CEV30010 ?
