Dear friends,
Need an solution from you all i am using Ingear AB OPC server and communicating On channel 0 DF1 serial driver PLC FlexLogixs, i was able to communicate sucessfully but the problem i am facing is with User Define Data Type Tags FlexLogix PLC i am getting very poor response of
Updates at HMI Level is that Ingear Doesnot support UDT type Tags or needs any further optimization at Ingear level or at the PLC level.
I had Increased the CPU time slice setting also but still same kind of response.
Pls advise me for the above problems what steps to take
Jack
Jack
