K
We occassionally implement our own XYZ "robots" for specialized high speed and accurate applications. I am interested to see if there is a motion control vendor that can automatically restore to the position that the motor was in when the safeguard was opened, and then continue the motion trajectory it was running from that point. This is very similar to how Epson Robots (and I presume other robots) function "out of the box".
We are finding that simply resetting the errors and re-running the motion program can often times be all you need to do, but there are times where you need to make sure you are clear of tooling, etc, which complicates your motion code alot. For very complex move profiles it can be very tricky to perform fool proof recovery and still make the code understandable 10 years down the road.
I know that many motion controllers can handle this if you are willing to write alot of recovery code, but I'm looking for the most integrated and seamless way of doing it. An ideal method would be if the servos could maintain position with a "safe" low torque setting until the safeguard was closed again. This may have to be hardware controlled in the drive for safety reasons, so maybe this one is more for an integrated system. I sense that the safety gods would throw down lightning over this approach, but it potentially could be made safe.
Thank you,
KEJR
Thank you,
KEJR
