It’s 2OO2 S/D GT, unless the motor doesn’t work yes you can do it but if it is a part of PM don’t do it.Is there a way for changing the pressurizing Fan Motor while the other one running whice the Fan is upstream the turbine Roof
WTF?????It’s 2OO2 S/D GT, unless the motor doesn’t work yes you can do it but if it is a part of PM don’t do it.
We have two pressurizing fanUnless you got 3 DIfferents Motor Fan installed ...
Well for your condition one only running and the standby is fail and need to change but how did you know it’s motor failure did you get alarm active or you have done Fan switching L63at 1-a/b in led and lag testing ? Always this step recommended before starting the GT to assure both are functioning properly?WTF?????
We have a motor failure. We a made an electrical test and we had found an winding faliureWell for your condition one only running and the standby is fail and need to change but how did you know it’s motor failure did you get alarm active or you have done Fan switching L63at 1-a/b in led and lag testing ? Always this step recommended before starting the GT to assure both are functioning properly?
Thank you for the update ! So finally how did you troubleshooted this issue ( with unit runing)We have a motor failure. We a made an electrical test and we had found an winding faliure
If S/D is close wait for replacement if not you can do it in precaution. Good luckWe have a motor failure. We a made an electrical test and we had found an winding faliure
All Gas turbines pressurizing fan has only 2 one running and one stand by lead and lagUnless you got 3 DIfferents Motor Fan installed ...
K | Turbine compartment monitoring for 9FA machine | General Communications Chat | 9 | |
M | Swirl effect in gas turbine GE frame 9FA | Power Generation | 2 | |
H | 9FA water injection | Power Generation | 3 | |
H | Gas turbine 9FA | Power Generation | 0 | |
OVER CHANGE FUEL TO GAZ 9FA | Process Control | 1 |
