I want to select a suitable flow meter for measuring water and process solvents with remote indication. I can not go with orifice plates as the density of the process solvent will vary from 750-1500Kg/m3. The line size is also small 1 to 2 inch.
Please suggest suitable cost effective options. I think turbine type and vortex. Will they work? Which will be more accurate and cost effective?
Apart from them any other suggestions also please.
