Dear all,
we have an issue with our OPC server which is connected to siemens teleperm xp dcs...
Our principal buyer wanted to our OPC server directly to their network. so that they can monitor all the data. Actually they want to monitor only 48 signals which are useful for monthly invoice purpose.
But our existing opc server having 1000 + signals. so they can monitor all the data which they don't require also.
so our target is we want to install another opc client which can pull data (only 48 signals)to this client from OPC Server. so we will give connection to our prinipal buyer to opc client only. so they can see only 48 signal data only.
so my request is how to install opc client and
and how to configure those 48 signals...
what is the compatible opc client for siemens opc server which connected to siemens teleperm xp.
Please help me....
regards
nivasnet
Please help me....
regards
nivasnet
You should be able to connect any OPC server to simaticnet and get data from it. The question is how much to you want to spend on the client. for only 48 pieces of data you may be best off purchasing a tool kit for developing you own client application which you can then provide to your customer. You can get some very useful tools from companies like Kepware Technoliges amd Software Toolbox. Kepwares toolkit is ClientAce. Software Toolbox has serveral ActiveX Controls which can be used to connect to the server and display the data.
Fred Loveless
Senior Application Engineer
Kepware Technologies
http://www.kepware.com
Fred Loveless
The MatrikonOPC Security Gateway allows you to restrict access to users on a per-tag basis. You can restrict the OPC client to only see the 48 singles they require.
http://www.matrikonopc.com/products/opc-security/opc-security-gatew ay.aspx
This should be exactly what you are looking for.
Eric Murphy - OPC Exchange - http://blog.matrikonopc.com
Hi Nivasnet,
What invoicing system is the data going to? Some OPC clients would be able to directly input the required data. That way, you could control what data you're sending to them. Otherwise, you could potentially give them access to a locked down OPC Gateway, such as MatrikonOPC's Security Gateway:
http://www.matrikonopc.com/products/opc-security/opc-security-gatew ay.aspx, that would only expose the 48 signals required.
If you're just looking to provide them a basic Excel report that gets the data directly from your OPC Server, you may want to consider Matrikon's OPC2XL:
http://www.matrikonopc.com/products/opc-desktop-tools/opc-2xl.aspx
Adriel Michaud
MatrikonOPC
Adriel Michaud
MatrikonOPC
Dear,
Thank you very much for your reply...before buying this software i want to know this software is suitable for our architecture.
my primary concern is, Is it possible to configure signals (only 48 signals that from our exsisting opc server) in opc security gateway pc?
if possible how to do that... please send details
i want to buy this software immdtly...
srinivasa.rao [at] alezzelom.com
According to Kentucky state law, every person must take a bath at least
once a year.
