R
Hi all.
I have an application where I have 10 mixers which can be operated manually or automatically. Every time a mix has been made (either in auto or manual mode) that mixer's counter will increment, so that you can see exactly how many mixes have been made in each mixer. As soon as you switch to auto mode, the mixer that has been used the least, should be flagged as the next one to be used. How do I do that with RS Logix 5000? I have an idea that you have to use dimensions in an array, but as far as I could gather, you can only sort one dimension at a time. So if you have an array with a)Mixer Number and b)Mixer Count, how do you sort the array so that the mixer with the least amount of mixes are at the top?
