G
Hi All,
I am using the Nanotech ST5709S1208 (0.9 degree, 400 steps for a revolution) motor in bipolar series configuration to rotate a light mirror mounted on its shaft. I have constructed a driver circuit using a half bridge circuit and a PIC16 microcontroller.
I find that the maximum I can drive this motor is about 1.25 - 1.4 revolutions per second without the mirror loosing step. I have tried microstepping the motor with half/8/16 and 32 steps and though I can increase the stepping frequency as the number of microsteps increases, the speed of rotation of the motor is still about 1.25 rps. This is a bit too slow for my optical scanning application. I have a feeling that I may be doing something else wrong since I am new to stepper motors. To control the motor I use a chopping waveform of 20kHz and a linear velocity profile to attain max speed
I would like to know what any of your experience is regarding the maximum speed of this motor in particular and steppers in general and why do you think I might be getting such a low speed in spite of the fact that the torque I require is quite low (load = small, light mirror) ?
Thanks in advance!
Govind
Thanks in advance!
Govind
