Hi All.....
One of our engineer did an application with a vertical axis,servo motor connected with a ball screw. When the machine is running at lower speed (2 M/Min) with out any load it is taking high current(5 Amps) and for higher speed(6 M/Min) with out load it is taking less current (3 Amps). What could be the possible reason for this. One of my friend said If I reduce the gains may be current taken by the servo will be come down.
Is that possible? Or what all are the chances for high current...
