L
Hi you all!
I have a question about Modbus Masters.
I want to know how i can solve the following situation:
I have one system that communicates, using Modbus protocol and RS485 bus, with some network analyzers. I would like to put another master on the line, besides the mentioned above, to make some requests to this network analyzers to.
The problem is that probably with two masters on the line the messages will get screwed and there will be collision for sure.
Is there any hardware device (to which i connect both masters) that i can use to connect both systems that is able to manage the requests on the line? This way this device would buffer the requests from the two masters and avoid problems on the line.
Or is there other way to solve this problem?
Thank you all
LPS
Thank you all
LPS
