First of all, I need a clarification about the difference between min governor and max. governor in the steam turbine control system. while I was following a steam turbine start up curve, it shows that the running mode of the turbine to be in between min and max governor in which I know later that is assigned by the turbine manufacture.
So what this two expressions stands for?
Ahmed
Ahmed
