How the thrust balancing on steam-turbine is done? In our case the HP and IP is integral. Where is the location of balance disk in this case? HP turbine steam expansion direction is opposite to IP turbine steam expansion.
R | Problem with thrust measurement - Bently 3300 XL | Instrumentation & Measurement | 0 | |
A | Maximum Axial Thrust Load in GE frame 9E | Power Generation | 0 | |
D | Setting Thrust Position on Bently 3300 | Power Generation | 1 | |
K | Thrust bearing Temperature | Power Generation | 0 | |
I | Motor Axial Thrust | General Automation Chat | 0 |
