To whom it may concern
We'd like to know about the criteria for choosing between using OP (Operator Panel) or IPC (Industrial PC) for the control system of a plant. I'd be thankful of you if you would read the following facts & E-mail your suggestions to me.
We have a powder milk plant to be automated. The plant is around 1500 sq.m. and consists of 4 parts.
1- CIP ( Cleaning In Place ) : to clean pipes & tanks,..
2- Homogenizer
3- Process: to turn milk into powder milk
4- Packing: to pack the powder milk in 2 kinds of packages
But at the moment we only want to automate the control system of CIP part consisting of 3 tanks (water, LYE, acid) & having 100 I/Os.
As I said above, we can have a local OP to control the CIP or we can have a remote control room equipped with PCs & printers to do this (& some day we may cover the control of the other 3 parts in this room, too).
I want to know which solution is better & considering the higher expense of the second solution (control room) , does it worth having a control room. some impartant parameters for a logical reply may be as follows:
1- cost
2- future expansion possibility
3- maintenance
4- work force
4- comfortability
5- reliability
6- accuracy
7- connection to MES ( Manufacturing Executive System) in future
8- Comparison from HMI based on OP versus HMI based on computer point of view
9- Reporting facilities(historical & real time)
Some facts:
The temperature is about 20 C
NO viberation & shock exists
Control system has a PLC ( Cj1, Omron )
The connection between PLC & HMI is through Ethernet
The heads of the plants don’t care about the difference, the just want to have no problem with low cost
Thanks for your cooperation.
Yours truly
Masoumi
2- Homogenizer
1- cost
3- maintenance
4- work force
4- comfortability
5- reliability
6- accuracy
Some facts:
Yours truly
Masoumi
