I need flow meter for accurate and consistent measurement of water flow from Cooling tower to Condenser. Application details are given below:
Pipe Size = 60 in
Pipe material = Carbon Steel
Pressure Class = 125 psi
Pipe location = Underground, manhole is available to install a sensor.
Total Pipe straight run = 100 ft underground from CW pumps (4 no.) discharge header to condenser.
u/s straight run from mounting point = 58 ft
d/s straight run from mounting point = 42 ft
Mounting orientation = Top of pipe, vertical
Flow Range = 20,000 to 100,000 gpm,
normal flow is 50000 gpm
Transmitter type = Loop Powered 24V, HART
Transmitter output signal = 4 to 20 mA (preferably with integral display in gpm)
I know about Verabar, Annubar etc. anybody suggest which is the best. I have only vertical mount choice while Verabar doesn't recommend it.
any other idea.
Pipe Size = 60 in
any other idea.
